First its the subtitle. I have ripped them using subrip as bmp. Then I imported them into DVDMaestro and in the subtitle-editor there I see my subtitles as white text with red background. So my question is how do I correct it so I can see white text with my movie without going through each subtitle image and change color 4 (the red one) opacity level to 0.
And secondly, how do I correct audiosync in Maestro. Because I had to re-encode the movie, I process the audio from DVD2AVI. The AC-3 file I got from it said audio delay -12 ms.
Go to where you can change the color for ONE subtitle. Instead of changing the color, change the palette of the red color to whatever you want. Since the palette is changed and your entire subtitle color were based on the palette, that's a global change.
Problems with subtitles using tsMuxer
By cruck in forum Authoring (Blu-ray)Replies: 3Last Post: 7th May 2009, 02:11 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00 -
BIG problems with subtitles!!!!
By patoja76 in forum Authoring (DVD)Replies: 1Last Post: 11th Aug 2007, 11:00 -
Problems with subtitles in movie
By Lythrana in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2007, 15:27
