Hello!
I want to convert some of my ol' SVCD to DVD format, but TMPG won't recognise the SVCD file ... (Not supported....)
What am I missing?
Guest
Did you copy your .dat file to your hard drive rename it as a .mpg?
Hello. -
Had the same problem just recently. You have to frameserve it using dvd2avi first and open that file with TMPGEnc. There's a guide somewhere on this site.
m2v.vfp is an VFAPI Plugin to tmpgenc.
if you have that file in the dir where you have tmpgenc installed.
then you donīt need to frame serv. -
TMPGEnc 2.55 < (Freewear )with 30 day SVCD plug-in,
The Nimo Codec pack
TMPGEnc Plus 2.57, (you bought it)
Install Power DVD 4
These provide the codec's
ProRes 422 (LT) 4.29GB wont open
By RenderFi in forum MacReplies: 8Last Post: 11th Dec 2010, 10:54 -
Downloaded movie wont open..
By bahnan in forum Newbie / General discussionsReplies: 7Last Post: 20th Jun 2009, 11:56 -
Help the prgramme wont open!!
By amber123 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 23rd Apr 2009, 07:51 -
Sony vegas pro 8.0 wont open my files.
By Blake_t in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2008, 11:44 -
.mov wont open in quicktime
By lonewolfsas2k4 in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2007, 12:25
