Just started learning the Phillips VCD Toolkit,
Decide to create a couple of small assets for a test disk, using TMPGEnc 12i, run a 5min PAL mpg thought the De-multiplex and saved to the correct file extensions .mpv/.mpa, loaded them in to the tool that comes with the toolkit "VCD Mux" and it say that the "error eof .....", tied the Simple De-multiplex same results eof error.
Back to the drawing board I thought
Using the .d2v/.wav files loaded them into TMPGEnc and created the Audio and the Video one at a time to the correct file extensions. This time the "VCD Mux" program says "Warning The last 2 AU`s were ignored"(What is it telling me?) but a mmd was created, but does not seam to work though. (but could lack of understanding of toolkit that is the problem)
Has anyone else get an error/warning free PAL asset into the toolkit, that works
Cheers
paul_tp
