Does Premiere (any version) support multisegment capture?
(edit) lol didn't read your other post, your already usin AVI_IO. my bad..
mig
<font size=-1>[ This Message was edited by: sdmig on 2001-08-13 15:03:33 ]</font> -
No, I don't use it, because I can not capture to huffyuv with AVI_IO.
I have several problems.
I'm running WinME.
Premiere 5.1 does not support multisegment capture.
Virtual Dub drop to many frames.
AVI_IO does not detect huffyuv.
->Win2k seem to be the only solution... -
I'm not to sure what you mean as to "multisegment captures"?
but if you mean how Windows ME, makes a new file name for every 2 gigs you capture,
adobe premiere 6.0 edits it without a problem, just import the two files and put them back to back,
No Adobe premiere can't capture in multiframe. You'll have to use AVI IO. But what's your use of huffyuv in your capture sequence? You can import the AVI IO files in adobe premiere without problems.
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17 -
Transition for Adobe Premiere
By traxstar in forum EditingReplies: 4Last Post: 25th Feb 2008, 20:05 -
Adobe Premiere CS3 vs 2.0
By hanugro in forum Video ConversionReplies: 0Last Post: 31st Aug 2007, 07:26 -
How does Adobe Premiere 2 rate
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2007, 23:08
