I have already ripped Toy Story (original) and I did a full File rip with DVDDecryptor, so I have everything on my HD. Problem is, using DVD2AVI, I get the repeating scenes in each language, and a search of this forum shows I have a multi angle DVD. Well, I have already sent the DVD back. Is there any way to re-rip the files, using my HD copy of all files as the source, and then I would turn off Multi-angle processing.
Thanks.![]()
Smartripper 2.41 allows you to open and re-rip files already on your hard drive. You could use it's stream mode to re-rip only the streams you want.
When you say stream mode, do you mean I could choose just the angle that is english?Originally Posted by wulf109
Yes if you select stream mode it will show you a list of every stream(angle) in the vob files. Select the video stream and whatever language stream you need,I guess your interested in the English stream. Just be sure to uncheck any stream you don't want.
Thank you all. I got it! I was trying to use SmartRipper with File mode too. Once I pointed it at all the movie VOB's it automatically selected Angle 1 and I was good to go. 8)
8)
DVD Audio Rip Issue (Muddled High End)
By RKelly in forum AudioReplies: 4Last Post: 28th Nov 2009, 14:38 -
New Toy
By hudsonf in forum Off topicReplies: 13Last Post: 16th Jul 2009, 01:12 -
What is Your Favorite Toy - Pictures Please
By Number Six in forum Off topicReplies: 2Last Post: 8th Mar 2009, 18:21 -
Rip issue
By 7abatrista in forum Newbie / General discussionsReplies: 9Last Post: 5th Mar 2009, 04:27 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 16:09
