Hi there
I downloaded a film (avi) and I want to put the subtitles in with virtualdub I.ve done that a view times already and I never had problems before.
Now when I try to do so I get no picture just the sound but when i play the movie with media player there is no problem at all, so the problem must be in virualdub I think... so I tried a few other movies( also avi) and The problem is with all of them.Can someone Please tell me what can suddenly be wrong with virtualdub ?????
thanx in advance
Maureen
Results 1 to 10 of 10
Sounds like the old codec problem. Download and install the Nimo code pack and see what happens.
Hello. -
I already have the Nimo codecs, and everything worked before thats why I can't figure out what has suddenly gone wrong?
Greetings
Maureen -
vdub 1.3c is the best
Where I walk, I walk alone. Where I fight, I fight alone. -
Hi
I downloaded virtualdub 1.3c but the problem stays i still have no picture just the sound
please someone help me!! -
Do you have it set in Video > full processing mode ?. Streaming wont display the picture. Also check under "Options" if you have the source and destination display "Switched on"
Yes everything stands allright and all I have is a Black Background with the sound of the Movie ..Can you than maybe tell me another way to put the subtitles in besides with virtualdub???
Why would I want to do that ?, I spend all my time trying to remove themOriginally Posted by mkaffa
Sorry, But I would make sure that there is nothing with the AVI you downloaded.
Then check your system to see what codec's you have installed
Control Panel > Milti Media > devices
Then use Vdub file > file information to see what codec's in use -
I've checked everything and the only thing that I can see that doesn't work properly is": PCLEPIM1.dll + PCLEpixl.dll thets what it says when I check devices ..but where are this files from and how can I reinstall them??
Greetings
Maureen -
Don’t know what those are, they are not on my system. If you have all the codec's installed you should see the frames just fine, playing in Media player is different to editing in Vdub. It still sounds like you have a codec missing, did you install them in with Nimo ?
If you right click the AVI and select properties... What does it say ?
Or in Vdub File > File information
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 02:06 -
Virtualdub keyframe picture doesn't match the actual video
By yuvid in forum EditingReplies: 1Last Post: 1st Feb 2012, 02:57 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 05:52 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 17:41 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 21:00
