hi just wondering how i would make a dvd ripp .avi when i ripp it, like i use smartripper to get teh vob files then i use dvd2avi for the audio of the dvd, but instead of using tmpeg to make it a mpeg, i was wondering if there was a program i could use to take the .d2v file and the audio fileand make it into a .avi file ,
VirtualDub, Adobe Premiere, even TMPGEncoder, short said, every software, that is able to generate avi files. None of these tools support :d2v files directly, so you have to wrapp it with VFAPIconv.
http://www.vcdhelp.com/convert.htm#frameserve -
But you also could use DVDx (see at http://www.labdv.com/dvdx). This package rips DVD's, usually directly to MPG but (at your request) it also can rip to AVI.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 16:10 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
how to make sure that your output format for autogk is either, avi, mpeg..
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2007, 07:00 -
How to make DVD using MPEG Video Wizard DVD?
By nightcat in forum User guidesReplies: 1Last Post: 6th Aug 2007, 14:52
