Hi
I use Smartripper then DVD2AVI then TMPEnc to do my DVD to S/VCD conversion. My question is.....
After entering the DVD2AVI file in TMPEnc do I use to the source setting in TMPEnc to create 2 files to fit on 2 CDRs or, create one full movie file then split them with another program. ??
The reason I ask is I'm wondering whether the audio video synch be any different using either of these methods.
Cheers
Fozzee
Its probable quicker to convert all the movie, then use TMPGEnc File > Mpeg tools > Merge&Cut
You do waste time stopping and starting in other programs, if doing sections at a time
Why should it be ?, a stream copy is done when you use Merge&Split its not re-encoded
I my self like to do the whole movie then demultiplex w/ tmpg and cut/multiplex w/ bbmepg: http://www.vcdhelp.com/bbmpegedit.htm
Cutting HD files
By surfer in forum EditingReplies: 2Last Post: 23rd Jan 2010, 14:06 -
Cutting sections of HD files
By Fire Foxer in forum EditingReplies: 10Last Post: 29th Nov 2009, 12:21 -
cutting FLV files
By shaema in forum EditingReplies: 2Last Post: 24th Sep 2009, 12:01 -
Cutting VOB files
By DELTAsnake in forum EditingReplies: 20Last Post: 6th Apr 2008, 17:23 -
Split/cutting files recommendation
By XDPD7 in forum Video ConversionReplies: 1Last Post: 9th Oct 2007, 23:36
