i was just wondering if i play a pal dvd on my dvd player and an american tv...will the picture look proper or will it be verry bad???
It depends on your DVD player and whether it has a built it PAL/NTSC converter.
What sort of player do you have ? -
no i mean if it will look proper...i am playing it on my x box using a region x type thing....do you think it would look proper???
Is your Xbox PAL compatible. If so, yes it will look proper. You should not be able to tell the difference
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
convert PAL HDTV 1080i -> PAL DVD 576i
By halsboss in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 22:13
