i need help with spruce up dvd
i import an mpeg change audio to 48k
create menu's
simulate the menu's
export, right here's were it goes wrong
spruce up goes through all it process then it save to HD
then it goes to write the dvd and i get an error saying it cannot write
and then aborts
any help!!!!!!
thanks
johnboy
Results 1 to 1 of 1
Help needed with BD Burning, PC can play burned BD but TV cant!
By Shirokii in forum Authoring (Blu-ray)Replies: 8Last Post: 17th Nov 2011, 15:15 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Capture and burning advice needed
By ccm in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 12:25 -
I want to change my burning program, advice needed
By jesterhud in forum Authoring (DVD)Replies: 4Last Post: 20th Aug 2007, 13:43 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
