Hi, I tried to convert a divx file using tmpgenc, but audio and video are out of sync (about 3 seconds from the start). The divx file has no bad frames (checked with tmpgenc). I seperated the audio track (saved as .wav, 44100 khz), and used tmpgenc to combine .wav with divx file as new avi, which is still out of sync. Any ideas?
Second question: aspect ratio: how can I analyse the aspect ratio of a divx (avi) file?
Last not least: my divx files are < 700 MB, should I convert to vcd with 1 or 2 CDs or svcd with 1 or 2 CDs?
Thanks a lot, guys.
In your Option-->Envronmental settings, make sure DirectShow is set at 4, by selecting Higher Priority by right clicking the Priority box.
If you like, you can also adjust the synch of your audio file:
http://www.vcdhelp.com/edit.htm#repairHello.
Ripboot after conversion video & audio sync is out by 1 seconds ???
By yamyoume in forum Video ConversionReplies: 5Last Post: 17th Oct 2011, 14:32 -
DV Type-1 to Divx video/audio sync problem.
By cgmarsh in forum Video ConversionReplies: 0Last Post: 10th Aug 2010, 15:35 -
Audio/Video Sync Issue with .mts File Conversion
By arturo_morosoff in forum Video ConversionReplies: 2Last Post: 4th May 2010, 09:52 -
Audio track out-of-sync with DivX/XviD media file after video was split
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2008, 03:30 -
WMV video and audio slightly out of sync on conversion to AVI
By Calidore in forum Video ConversionReplies: 8Last Post: 10th Jul 2007, 08:48
