  1. I have a problem with the cdrwin when recording the file cue
    it jumps me an error START DAO RECORDING command failed on device 1:0:0 cuesheet was rejected by the CD-ROM recorder
  2. I am also having the same problem.
    Also CDRWIN doen't detect my Lite-on writer. It detects my hp cd writer.
    Anybody know what is wrong ?
  3. Banned
    Jun 2001
    UK
    Does your writer work with DAO (Disk at once) if its not supported, then you wont write in that mode, and need to use TAO (track at once)
    What has this got to do with helping you copy protect a VCD/SVCD which you cant anyway
