  1. I want to know how i can rip audio from .avi file or any other video files divx, mpg. And i want to convert it in mp3 or wav, so i will be able to listen it on my mp3 player or burn audio cd, to listen in the car or whatever.
    So basically i have movie and i want audio only and make it mp3 or wav.
    Any help will be appreciated. Thanks!
    Apr 2002
    The State of Frustration
    Load the video into Virtual Dub. Select File-->Save wave.... When the wave file has been saved, load it into Gold Wave. Change it into stereo if you want, or just go ahead and save as either .wav or mp3 -- voila!
    Hello.
  3. Thanks alot, i'v been searching answer to that question for ages, and then i found that wonderful VCDHelp Forums.
    Apr 2002
    My pleasure 8)
    Hello.
  5. Is there any other way or program to rip audio? Cause that wav with VirtualDub is kinda weird it plays fine on Winamp, but when i trying it put it in my mp3 player i getting Decoding errors, and then i used Gold Wave to convert it to 8bit mono, it did some noises, then 8bit stereo that i couldn't transfer to mp3 player. So i want to try and convert it to mp3 and see if it will work, but Gold Wave mp3 covertion doesn't work for some reason (no codecs i think). So i tried about 5 different wav to mp3 coders but it doesn't convert it right, all i can hear is some noises in winamp.
    My mp3player is Creative Nomad JukeBox 6gb.
