Hi, I have cut and joined some video clips of asf file. I am stuck with deleting the audio. i need to delete the audio and inserting a new track. can i know what software should i use. Plzz help thanks so much for your time.
Try Vdub 1.3C , Load ASF, but select the audio as a difference source, you need to save out as AVI
Or TMPGEnc, it also loads ASF and can have a WAV for audio input,
file > output to file > AVI -
Hi KingJohn,
thanks for your reply, i really appreciate it so much. I will try it.
Trying to delete sections of a movie with VirtualDub
By VanZan in forum EditingReplies: 1Last Post: 19th Nov 2011, 14:04 -
converting asf file audio sync issues
By andy99 in forum Video ConversionReplies: 4Last Post: 21st Jan 2011, 03:09 -
By andy99 in forum AudioReplies: 4Last Post: 20th Jan 2011, 19:41 -
How to delete/crop unwanted parts from a movie
By metedina in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2009, 21:43 -
Taking Audio from movie file, then burning audio to cd-r
By Justnmnmn in forum AudioReplies: 5Last Post: 22nd May 2009, 17:44
