I have always left the setting at the default when ripping/encoding mpeg2 for dvd copies, which is "interlaced" but now I am wondering if I should use one of the other settings (3:2 pulldown, non-interlaced, etc)
What do you all do?
Andy
Results 1 to 11 of 11
You have to specify what encoder you are using and what you are trying to accomplish. If you are doing DVD rips you should probably almost never put interlace (interlace will only be the case in TV captures and occasionally certain PAL DVDs from Australia.)
Macros -
You generally should use the same format as your source. For example, if you encode from a DVD rip that is progressive (FILM), then use progressive. If you are encoding a TV capture, then use interlace. Also, if you are encoding a laserdisk capture (also an interlaced capture) then use the interlace option.
But as always, experiment with your settings with a short clip (~10Megs) from your source that has some fast action in it to see if you will be satisfied with the results. -
i am taking mpeg2 captures I made with my 7500 and re-encoding to fit onto dvd. the captures are from my dvd player into my capture card.
Andy
oh yeah, I am using tmpgenc -
Anything interlaced sucks. Its a holdover engineering trick from the 1930s to save bandwidth in broadcasting. If you are using MMC with your ATI 7500 capture Mpeg 2, I-frame only, progressive, 15 Mbps, 100% quality (motion estimation) 3:2 pulldown for DVD source only (not for tv tuner) then reencode with tmpegenc. I use Xmpeg with the latest ligos premiere plugin because it works for me. (Notice to all flamers: I do not want to waste any more time arguing which encoder is the best, fastest, and can beat up your mother best etc... Use whatever encoder gets you off!) IMHO for an ATI card its the best way to capture as you let the hardware deinterlace and NOT by dropping a field as in 320 by 240 capture and you don't have to extend encode time by deinterlacing a DV or Huffyuv avi!
3:2 pulldown in the capture settings (to capture from the svideo of my dvd player) ??
then, what do I set tmpgenc at when I am re-encoding for it to fit onto a dvd?
thanks so much for the really helpful response, though, I love it when someone takes the time to go into detail (and it sounds like you have done what I am doing)
Andy
You will use whatever template you want vcd, svcd,dvd,cDVD, blah..blahVD, put motion estimate on slow - high quality NOT slowest and make sure the fps is 24 (23.97) for NTSC. Mpeg 2 players will playback 24fps on a computer screen and 29.97 in a settop player, hollywood magic out to tv, etc.... The header of your 23.97 mpeg stream as encoded by tmpegenc tells the player to "telecine" (repeat 6 frames for every second of video) for NTSC.
why is slow better than slowest? and I am still not sure what setting to put it at for highest quality.
And did you say 3:2 pulldown on the ATI 7500 settings?
Andy
anybody? I'm sitting here in front of my computer waiting to start my project...
Andy
Well, don't rush your project yet. Before you start, you better have some understanding of progressive frame, interlaced frame, telecine, inverse telecine(IVTC), 3:2 pulldown, what your source is, features of your capture card, etc. Why don't you rip your DVD instead of capturing?
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 23:09 -
Interlaced or not
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 26th Oct 2010, 10:17 -
Interlaced but not
By tb582 in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2010, 15:08 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 10:16 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 19:48
