I tried converting "The rookie" avi with tmpgenc but when i load the avi it wont load the audio so i went to virtual dub did full processing changed to 44.1 khz and hit save wav it gave me this "The requested audio compression is not compatible with th e input format. Check that the sampling rate and channel count of the input match those of the requested format." so i just tried loading the avi into LSX-Mpeg encoder but that said "This program supports only PCM audio format with sample rates 11025, 22050, 44100, 48000 hz." well then i found virtual dub would give me that error with every avi except the ones that say "improper vbr encoding etc." WHAT THE HELL DO I DO TO ENCODE THE ROOKIE!!!
REENCODE THE WAVE FILE WITH ANOTHER PROGRAM TNEN TRY TO RELOAD IT
Where I walk, I walk alone. Where I fight, I fight alone.
Rookie with a Canon Vixia HF10 with no software
By westcitysf in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2011, 00:38 -
Rookie is closer to making DVDs!
By rjack in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2009, 17:39 -
Rookie DV to computer to DVD questions
By rjack in forum Newbie / General discussionsReplies: 5Last Post: 9th Jan 2009, 18:42 -
Audio messed up when burning .mpeg on DVD +R
By greenda4 in forum AudioReplies: 16Last Post: 19th Nov 2008, 16:52 -
rookie help/vista issue
By cwb in forum DVB / IPTVReplies: 7Last Post: 2nd Sep 2007, 20:13
