I've been trying to convert TMD movies to vcd. I follow the guide...i decompress the audio with Vdub....then i use TMPGEnc to covert to mpeg-1 VCD format. It says that the output will be 352x240@29.9FPS....but when it is finished encoding and i try to burn it using ez-cd creator....when i add the file it has "???" next to where it says format and it lists the file as being 352x264@29.9 fps and it won't burn it....what am i doing wrong...please help
Did you select the VCD template from the Load option?
Hello. -
Yes i did....it even said the output would be 352x240...but then when i load it to ez cd creator...it comes up 352x264
FLV won't play correctly in another computer
By kfain in forum Video ConversionReplies: 6Last Post: 29th Dec 2011, 13:10 -
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 14:08 -
.avi files that won't work correctly!
By RolloSwe in forum MacReplies: 10Last Post: 24th Feb 2011, 11:45 -
By RolloSwe in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 17:41 -
.mpg won't open/burn correctly-help!
By keltoid in forum Video ConversionReplies: 6Last Post: 14th Dec 2009, 12:11
