  1. basic question/confirmation:
    if i am capturing from NHS tapes into the system to finnally create a VCD,
    is there any point in capturing above 352x288?
    would capturing at a higher resolution and then using tmpgenc to render it to 352x288 to create a vcd improve the quality of the final vcd? (given all other parameters being same)
  2. Yes it would. Slightly, but noticable.
    BUT: Make sure that capturing at a higher res doesn't give you frame drops. and try to capture at a multiple of the current resolution. 704x576 is good. This makes even better quality because when reencoding it doesn't have to be scaled on some strange size (1:17543) instead on simply (1:2) for both horizontal and vertical pixels.
    Hope this helps.
    Greetz,
    pSyChO dAd
    The difference between genius and insanity is only measured by success !
    Apr 2002
    The State of Frustration
    Yes, but to be sure, your can capture a short video at each resolution and convert them to compare them for yourself.
    Hello.
