Can't seem to figure out how to change this *.txt file to *.mpg file that it is supposed to be. Is there a tool or something? Please help.
	If your Windows is configured as default, you are not viewing the extensions of most files. If that is the case, and you try to change the .txt to .mpg, Windows will be helpful, and append another .txt to the file, making it movie.mpg.txt -- which still won't work for you. So, go to the Folder Options -> View in any folder, and be sure the Hide Extensions is not checked. You should then see extensions on all files. See if the file in question has a .txt appended, and you have your answer. Now, all this presumes, of course, that the file is only misnamed. If it was corrupted in download, you may have to download it again. Good luck!
  .mpg.txt helpBy Draconis in forum Newbie / General discussionsReplies: 3Last Post: 6th Mar 2011, 00:05
  Can't convert files downloaded from a file hosting siteBy ibzomie in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2010, 20:27
  Can Video File Be Uploaded (file share) And Downloaded in PAL CountryBy studioc in forum Video ConversionReplies: 9Last Post: 3rd Nov 2009, 15:34
  cannot convert downloaded file in xvid4pspBy suevee in forum Newbie / General discussionsReplies: 2Last Post: 4th Aug 2009, 19:55
  I have downloaded file clips in .divx how can I convert to .avi?By Ricksasha in forum Video ConversionReplies: 8Last Post: 13th Nov 2007, 14:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
