  1. hello,
    Everytime i try to use Virtual dub to join together two MPEG files, it keeps on crashing. It tells me that because have a codec on my computer, it cannot function properly. Well, i tried deleting the codec but it still wouldn't work. I'm not a computer whiz, so i can't tell you all the info you might need. But i do need help.What should i do?
    Thanks for your help!!
    <font size=-1>[ This Message was edited by: kooky_e on 2001-08-14 00:22:41 ]</font>
    Jun 2001
    use remarkable free software [TMPGEnc], easy and simple rather than trouble shooting the problem.
  3. VirtualDub is for AVI.
    MPEG editing requires other tool(s). Such as TMPGEnc.
    BeTa
