This is my problem... : When i rip Saving private Ryan using Dvdx ( I'm stubborn and wants the subtitle ) the movie is about 1 second after the sound. The quality is perfect...
The original dvd is ntsc , region 1 , and i'm changing it in Dvdx to Pal. Dvdx warns me and says that the input frame rate is not the same as the output and the program will try to adjust that in some way.... ( something about force 24Hz....)
I've tried smartripper , dvd2avi and TMPGEnc and it works just fine. No out of sync problems.... But as i said..... I'm stubborn and want's the subtitle...![]()
I've ripped a lot of other Dvds with Dvdx and never had any problems.... Is it because of converting to Pal or what ???
I use a 1,7Ghz Dell , 100Gb/512mb , 64 mb Geforce3 Ti500........
Results 1 to 1 of 1
Easy ripping with DVDx 4.0
By Starbuck2010 in forum DVD RippingReplies: 41Last Post: 11th Dec 2013, 00:17 -
Crossover cable / AC Ryan PlayOn
By ringo12 in forum Media Center PC / MediaCentersReplies: 3Last Post: 9th Nov 2010, 08:38 -
AC RYAN DVR HD,I need help with the recording system
By densleyporter in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2010, 10:15 -
AC Ryan : Toggle betwwen PAL & NTSC for composite
By warresg in forum Media Center PC / MediaCentersReplies: 0Last Post: 10th Jul 2010, 12:46 -
What happened to Ryan?
By Jomapil in forum Video ConversionReplies: 6Last Post: 16th Jun 2009, 14:14
