I have a ATI All In Wonder 128 Pro which outputs to mp2 format. i am trying to create an SVCD. i am therefore attempting to convert the mp2 file to mpeg to burn it but utils like TMPGenc claim the file is unsupported or return an output stream error.
ANY help appreciated!
it's an MPEG-2 file, the extension is irrelevant. you can just rename it .mpg and it won't change anything. if the file is otherwise witihin SVCD specs when you capture it, just run it through the "fix12c.exe" utility, demux, and remux it with TMPG, and it should be ready to burn.
Apologies for this but what is 'fix12c.exe'?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
it changes some wrong parameters in the MPEG headers that ATI, TMPG 12c/d/e and others put into them. specifically, the 'Display.Width" and "Display.Height". some dvd players will actually read these flags (pioneer is the main one) to try and show the image at proper size. lots of players ignore them. but if they're wrong, sometimes you get image stretching or squishing, and it only takes 5 minutes, so i think it's usually worth it anyway. here's a link to the program and more explanations...
http://www.geocities.com/eby_vdo/
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=51502&forum=1
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=49812&forum=1
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=48009&forum=8
How do I make a Blu Ray disk from an MP4 or MP2 file?
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 04:26 -
Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
By 2397to2997 in forum Video ConversionReplies: 12Last Post: 18th Aug 2010, 15:42 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Demuxed mpeg to mv2,mp2 with command line
By vtr in forum ProgrammingReplies: 4Last Post: 15th Sep 2008, 02:22 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 16:53
