Which program do u think is the best for re-encoding them oversized DVDs. Which is the fastest and more reliable etc.
if my choice is to use rempeg or tmpegenc, then i choose to buy the retail dvd =) neither produce results that are acceptable to me. i very very rarely use rempeg to transcode a vob and only when that vob : 1) is dvd extras 2) has more than 5 PGC . otherwise what's the point. you get poor quality, no consistency, a huge wait time. CCE will give you output that is dvd quality even if it is a lower bitrate than the original work. and it provides you with much more control and maybe equally important a realtime or better than realtime encoding environment
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
