Is there a way to view a half downloaded avi file? when i play it with power dvd or windows player i get an error file not supported. any ideas?
You need to copy the .dat file to another location and rename it to AVI. Then open it up in TMPGEnc and select preview (No sound)
Use the speed button to move faster
If it fails to load then you may have a codec missing.
For Vdub, use File > Load
but check the "Pop up extended open options"
Select "Re-derive key frames flags" -
Nope TMPGEnc crashes when i load it and Vdub gives me a new error "Invalid AVI file: Not a RIFF file" and its a .part file for edonkey. maybe it hasnt got enough data to play.
Try downloading DivFix and running on the dodgy AVI.
Note: There is an option to create a new repaired file, if this is not set then it'll overwrite, this is automatically done if you drag-and-drop onto the DivFix app.
You'll find it at http://www.divx-digest.com/software/divfix.html
Latest version should be 1.07
Works for me all the time :P
Good Luck. -
Originally Posted by Lost_Soul
I have downloaded a movie but it claims to need a avi extender
By dragonext in forum Video ConversionReplies: 9Last Post: 25th Sep 2011, 22:21 -
no sound with newly downloaded .avi file
By JediPM in forum MacReplies: 7Last Post: 30th Dec 2008, 15:29 -
Downloaded AVI to DVD problem
By karlh10 in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 14:55 -
Codec problems with downloaded avi files?
By aelfheah in forum Video ConversionReplies: 3Last Post: 16th Jun 2007, 07:48 -
AVI File Downloaded from torrent
By mps in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 10:54
