Question: is this new version better than the old 2.5 and will it work with DVD2SVCD like 2.5?
thx
Most of 2.64's improvements were to CCE's audio decoding, which isn't even possible to use on AMD systems. As far as video encoding quality, 2.5 is probably just as good as 2.64.
2.64 does not support AVS input directly so no I don't believe any version of DVD2SVCD supports it, though you can manually use Link2 to frameserve your avisynth script.
Bottom line is that if you have both 2.5 and 2.64 your probably better off just sticking with 2.5 until the new version of CCE is released later this year. -
the new cce-sp 2.64.01.10 does support avs directly like 2.50. you don't need link2 to use avs script. unfortunately the actual version of dvd2svcd does not suport it yet, but it will be supported.
Yes and no. ccesp2.64.01.09 and newer support *.vdr and *.avs. The earlier versions of ccesp 2.64 do not.
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 12:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 19:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
