hey,
I'm Having a major problem. Whenever i try to convert an avi, when it's about 99% done, it keeps telling me that i don't have the right dvd software, so i can't play back the movie. Then i press ok, and it deletes the conversion and starts all over again. It is VERY annoying. I'm open for suggestions.
Thanks a million.
On 2001-08-12 14:33:20, kooky_e wrote:
hey,
i have to apologize to everyone, because i put the same post at the end of three threads when i first visited this site. I'm new to this site, and i didn't know that i could create a new post, so i added a reply to another post. I'm sorry if i have caused any inconvenience to anyone. Thank you.
Thanks a million.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
I'm still open for any suggestions that will help my problem.
Thany you for your help. -
Probably the reason you can't get a response, is you are not providing enough information, like...
1) What capture card are you using?
2) What is your processor type and speed?
3) How large is your hard drive, and is it designated just for video capture/editing?
4) How much memory (RAM) do you have installed?
5) Is your OS compatable with the program you're using for capture?
I don't know everything, but I do know that people here are willing to help you with your problems if you give them enough info. -
Thanks for you're help (even though i didn't get any) but i figured out the problem and i was able to fix it. Thank you for you're time.
i solved it by changing the priority in the settings menu.
if u are having the smae problem as me, do what i did. Launch TMPGEnc> go to Options> Environmental Settings> VFAPI plug in> Right click on AVI VFW compatability Reader, and click on higher priority until it reaches to the number 0. It worked for me, it might work for you. I hope i was of some form of help.
11 Programmes used - still can't join mp4 successfully?
By The.King in forum EditingReplies: 20Last Post: 13th Oct 2012, 03:32 -
Can't get multiAVCHD to successfully create an AVCHD folder???
By jwmghf in forum Authoring (Blu-ray)Replies: 15Last Post: 17th Nov 2011, 13:37 -
Have you successfully backed up the Casino Royale?
By coody in forum DVD RippingReplies: 122Last Post: 27th Sep 2010, 03:21 -
Tin Man (from Universal HD) - anyone able to successfully convert to MKV?
By Tiernan in forum DVB / IPTVReplies: 6Last Post: 20th Mar 2010, 16:55 -
is there a way to burn using prime successfully
By ricanchriz in forum Newbie / General discussionsReplies: 3Last Post: 8th Feb 2008, 18:10
