Hello
I have a P4 1,6Ghz, 512 MB ram, geForce-2 MX/MX 400 and winXP pro.
I would like to ask you something. Perhaps someone had the same question in the past but I thing this issue is always in great interest.
I have a DV camcorder. Untill today I was capturing through Adobe Premier or other programs in DV avi format receiving huge avi files. Can I capture directly in mpeg 1 or 2 ? I know that perhaps I will have dropping frames and CPU isn't fast enough for such a hard work. My CPU is good enough for this work ? also what I have to do to capture directly in mpeg from a DV (Firewire- IEEE 1394) ? should I buy a mpeg card or something to have the best quality and to avoid problems (droping frames etc) ? Also which software support direct mpeg capture from a DV camcorder through firewire ?
thanks
Your CPU is fast enough for capture. how fast is your Harddrive 5,400 or 7,200 udma 66,100 or 133. I recomend you to capture to avi and them convert to mpeg because when you capture to mpeg on the fly you loss quality and if you want to edit and re-encode you lost quality.
encode direct to avi and from premiere frameserve to tmpeg.
Feel my Power Flaming Black Dragon Wave!!!! -
this is what i'm asking about. Do I need a mpeg card or any other hardware to capture with no loss in quality directly to mpeg or this system is good enough for such a work ? (my disk is 40GB 7200 ata 100).
And something else If i have a 30-40 minutes DV avi movie (some GB data file) how much time it takes to convert it in SVCD format (or in mpeg1 file) with this system ? do i need an mpeg card ? -
Forget the mpeg card .encoding 30-40 min DV avi in Tmpeg 2 pass, standard SVCD template is about 2 hours..
HDMI capture issues
By channelk in forum Capturing and VCRReplies: 7Last Post: 28th Mar 2012, 17:19 -
VHS Capture and tracking issues
By nonsuijuris in forum Newbie / General discussionsReplies: 5Last Post: 29th Dec 2011, 16:10 -
hauppauge hd pvr 1212 Capture Issues
By jwack in forum Capturing and VCRReplies: 10Last Post: 19th Nov 2009, 21:17 -
Mpeg Streamclip synch issues
By filter5 in forum Video ConversionReplies: 1Last Post: 11th Aug 2008, 22:41 -
Having issues with Pinnacle 10/Dazzle; what capture technology do YOU use?
By Grunberg in forum Capturing and VCRReplies: 6Last Post: 23rd Jun 2008, 10:04
