Hi all,
I have an AVI file, for which i created subtitles with MovieFactory and MicroDVD.
Now I want to create a CD that I can play on a DVD deck that will have this movie with the subtitles...
How do I do that ?
Thank you!
_____________________
He Says there are no easy answers. I say "He's not looking hard enough"! -
Do you want the movie subtitles to be selectable or permanent?
Hello. -
The preferred option is to have a possibility to turn the subtitles on/off, but if there's no other option, or it's much easier, I don't mind having the subtitles permanent...
Thanks!_____________________
How are the subtitles saved, as in what format?
Hello. -
I created them with RadLight and MicroDVD. meaning all the following formats are available:
DVDSubtitle
IAuthor
JacoSUB 2.7+
MacSUB
MicroDVD
MPL2
Philips SVCD
Phoenix Japanimation Society
PowerDivX
RealTime
SAMI Captioning
SonicDVD
SubRip
SubSonic
SubStation Alpha
SubViewer 1.0
SubViewer 2.0
TMPlayer
Turbo Titler
ZeroG_____________________
I would load the avi file in VDub. Load the subtitler filter, and select the subtitles file. Frameserve into TMPGEnc with the VCD template loaded. The result should be a VCD-compliant file ready to be burned with VCDEasy or your favorite authoring program.
Frameserving:
http://www.vcdhelp.com/convert.htm#frameserveHello.
Add permanent subtitles to S/VCD,DVD,AVI with ffdshow/vobsub
By Baldrick in forum User guidesReplies: 74Last Post: 4th Oct 2011, 05:11 -
Creating my own subtitles and adding them to an AVI (divx) file? Best way?
By Chrushev in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 05:12 -
Creating subtitles to a DVD exported project
By aashkar in forum SubtitleReplies: 6Last Post: 11th Aug 2009, 21:52 -
Creating a DVD with Menus and switchable subtitles on Mac OS X
By koke_broke in forum MacReplies: 7Last Post: 27th Mar 2009, 13:43 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
