Hi eveyone.
I was wondering if someone could tell me what a codec is and what it does to your computer and avi file. Also what is a ifo and vob files how can I watch them if I can, and lastly what is a dvd protectiion and how it works????
Thanks for your help
axg275
Codec means COder DECoder - the software on your computer that allows programs to decode video and audio files encoded in a particular format. A codec also allows programs to encode a file into a particular format. For example, DVD video is [;ayed back with the MPEG2 codec so you can watch a movie on your PC; audio CDs that you rip to store files on a Rio use the MP3 codec. There are hundreds of video and audio codecs, but most of us only deal with a few of the most popular (MP3, MPEG1, MPEG2, MPEG4, etc.)
An AVI file is just a wrapper around data--inside the AVI file is information on which codecs to use plus the video/audio data. The same concept applies to QuickTime .MOV files.
IFO files are sort of a table of contents for a DVD player when reading a disc. VOB files are Video Object files that contain video, audio, menu, etc. data on a DVD.
Most commercial DVDs have encryption so that you can't do a simple disc-to-disc copy if you have a DVD burner. It also prevents you from simply extracting data from VOB files. You have to use a ripping program to decrypt the data. -
Reading this post made me think if it would be posible to watch a dvd through ur Cd-Rom with an mpeg2 codec? or do u need a dvd rom wots the difference?
You can't watch a DVD in a CDROM because you won't be able to read the disc. The information stored on a DVD Disc are stored physically closer together then information on CD Disc, that's why you can fit 4.7 GB on a DVD and only 700MB on a CD. Because the bits are store closer together you need a smaller laser to be able to read them and the laser on CDROM's are not adequate.
So in summary you can't watch a DVD in a CDROM, but you can watch MPEG2 video's on a CD... ie. SVCD. SVCD and DVD uses the same codec, MPEG2, but DVD's are higher resolution and have a higher bitrate that's why the picture is better.
-LeeBear
codec
By natty in forum Newbie / General discussionsReplies: 22Last Post: 3rd Apr 2011, 13:42 -
Which codec?
By Andyncu in forum Video Streaming DownloadingReplies: 5Last Post: 13th Feb 2011, 08:11 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41
