  1. OK here is what I want to do. I want to take a dvd9 movie, and burn it to 1 dvd-r. I want to keep the menu's and only one audio and one video track. Here is the way I am doing it. (only have done about 3) Please let me know if I should be using diff software or be doing it differantly. Thanks
    I rip all files using the file mode in smart ripper. Then I open up ifoedit and rip out only the track that I want. Then If my total number of files is to big for my dvd-r I re-encode them using rempeg. (I know I should use either tmpeg, or cce but not sure how yet) then I take these files and do the get vts and all that finalizing stuff in ifoedit. When I go to burn nero and prassi will not burn. Gives me some sort of video_ts is invalid or something like that. So I have to create an image file using this dvd image program then burn with dvd decrypter. I do not like this cause even when I tell dvd decrypter to burn at 1x, it still uses 2x. It then does work in my ps2, and xbox. Does not work in my sony dvd player, but that thing is very picky anyway.
    Now I am not sure if I need to use dvd2avi or anything like that. I have read every guide and they are all differant. Please give me some advise as to what I am doing wrong, and what I should do to help quality.
    Thanks!
  2. the reson it give u a VIDEO_TS error (In Nero) is because u have it on DVD mode, change it to UDF/ISO. then burn it back.
  3. Thanks, Ill give that a try. Anyone els got anything that can help me out?
    TooHuge
