  1. How do I use Visual Dub to remove TV Logo?
    Apr 2002
    The State of Frustration
    Use the filters DeLogo or Logoaway.
    Hello.
  3. But how do I get to that option?
    Apr 2002
    Select Video-->Filter....If either of the filters are not in the list, you will have to download them:
    http://www.republika.pl/vander74/virtualdub/
    http://sauron.mordor.net/dgraft/index.html
    Install them in VDub's plug in folder.
    Hello.
  5. Thanks alot for your help Tom. I hope that I get it this time.
    Sep 2001
    Canada
    Why the heck is it that whenever I try to go to http://sauron.mordor.net/dgraft/index.html its down...
  7. Hey gang,
    I havent had a chance to do it myself but when you use remove the TV Logo using Visual Dub, does it just cover the logo or does it actually remove it and you can still see the video that is behind it?
    - Bryan
