  1. I've been following the Foolproof guide to converting DivX to SVCD using CCE, and I don't know whether I've missed something, but I'm having problems !
    All is fine until I get to the point of 'start frame serving' in virtualdub, and when I click OK, and then save the vdr file it looks like it's not doing anything !!
    It goes to a small box like the guide says but then stops, the number of frames served does not alter from zero ! How long is this supposed to take ?
    Anyone give advice ?
    Panther
    All say Grrrrrrrrrr......................
    May 2002
    I recommend using Fit CD to create an avs script file for CCE, its quicker and a lot easier than using Virtual Dub, and can be used with DVD d2v files too.
    CCE2.50 and 2.64 both take avs files.
  3. Member Gargoyle's Avatar
    Jul 2001
    Southern New Jersey, USA
    Once you click the "start Frameserving" in VDub and save the .VDR file, just open CCE and select the .VDR file as the input. (use the "all files" option when browsing for the .VDR file)
