OK, I have a AVI movie that is about 120 mins.
Using Ulead I copied the first 60mins to mpeg (VCD format) with no errors.
When I tried to copy the second 60 mins to mpeg (VCD format) the audio was way off and only lasted about 10 mins.
Then I tried to convert the entire movie from avi to mpeg(vcd format) thinking I would just split it later in the new format. Well the audio was correct for about the first 15 mins and then went crazy for a few minutes and then no audio.
Any ideas?
I need to either convert that second 60 mins into mpeg(vcd format) with correct audio.
OR
Convert the entire movie to mpeg (VCD format) successfully with correct audio. I can cut a correct mpeg (VCD format) version later.
Load the video into Virtual Dub. Select File-->Save wav.... Load the video into TMPGEnc as input video and the .wav file as input audio and convert to your VCD template as before. Good luck!
Hello. -
OK I can't find the .wav file on my system. When I used TMPGenc it loaded the .avi file in both the Video and Audio spaces and the final mpeg had NO audio.
I did a search for a corresponding .wav file and came up with nothing.
Any ideas?
Just reread your post. I don't have virtual dub. I'll see if I can find it and use it to create the .wav.
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
missing mp3 audio codec in ulead when saving as avi
By gabz in forum Video ConversionReplies: 3Last Post: 24th Jul 2011, 17:23 -
I have a problem using Ulead DVD Movie factory including.AVI Files, the pro
By OggO1984 in forum Authoring (DVD)Replies: 1Last Post: 19th Dec 2009, 09:42 -
Audio problem when converting a MPEG file to AVI
By Kareng in forum ffmpegX general discussionReplies: 9Last Post: 18th Jul 2008, 18:50 -
By Kareng in forum AudioReplies: 1Last Post: 2nd Jul 2008, 16:56
