  1. hi there i would like to know what the best settings r for converting divx to svcd
    im using tpmeg and find it rather easy to use but im not confident enough to try different settings
    i currently use 2000+ bitrate for vid and the default for audio
    i split the divx into 2 because my dvd player doesnt support xscvd or xvcd.
    i also find that the svcds skip alittle and the divx dont i use high on the motion comp.
    any help would be a bonus
    Apr 2002
    The State of Frustration
    Are you using the templates that came with TMPGEnc? If you are, then you may want to try the Kwag templates at www.kvcd.net.
    Hello.
