I'm giving a try to this premiere plug in encoder.
The normal way I use for cvd generation with oder encoders is start from svcd template and change the frame size.
LSX doesn't like to produce svcd streams with frame size out of spec(576x480).
Using DVD or MPEG2 template as base point I didn't succed.
Do you know any workarround?
Results 1 to 1 of 1
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 22:46 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
