I created a Project using DVDit ver 2.1 LE. The project size is 4.6 Gb. When I try to build the DVD I get the following error <The content of this project exceeds the 650 Mb of availiable space on the CDR>. I have a HP DVD200i running on Windows 2000 and DVDit apparently can see the drive. Since I could not burn the DVD using DVDit I created a DVD folder (Video_TS) then I tried to burn it using Nero Express 5.8.2, but since the project is 4.6 Gb I get a not enough space error. How or what software can I use to finally burn my project?
4.6 GB won't fit on a DVDR cause they only fit 4.37 GB.
www.vcdhelp.com/dvd#1000
Help burning Pinnacle project to DVD...mpg, converting, etc.
By jubbilee in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2011, 15:37 -
Editing a project in HD, but burning to DVD in SD...
By Huntr777 in forum MacReplies: 6Last Post: 14th Jun 2011, 21:20 -
Problem burning a project on to a DVD from TMPGEnc Author 3
By vhsal in forum Authoring (DVD)Replies: 5Last Post: 21st May 2011, 19:25 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 18:08 -
Burning multiple copies of a project using Audio DVD Creator
By scratcher in forum AudioReplies: 2Last Post: 28th Sep 2007, 17:28
