Am i the only one who has huge problems with it when it comes to burning..
First of all it seems to fux up my nero..Wich is probably common when you have diffrent burning software programs i guess..but then it makes the mpg files alot bigger than they really need to be..for an example an mpg file in nero is say 795meg but then in umf its 810 wich is more than my burner can handle..And its not the added menus..its the mpg files them selves..Its the same in vcdeasy to a lesser extent..
So im wondering is there any way to get around this without cutting anything? Like say make an umf image and then bust it open and add the files in nero and burn? Or any other smart idea will be appriciated.
thanx!
There may not be a problem. Many programs will show different sizes for the same file depending on whether they are rounding to MB or are showing X millions of bytes. I find I can burn a BIN file of up to 814 MB before going to overburn.
Ulead Movie Factory queries
By Mark Wynn in forum Authoring (DVD)Replies: 2Last Post: 11th Apr 2010, 20:42 -
Ulead DVD Movie Factory 6 Plus
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 12:22 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:20 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 07:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 18:20
