  1. I've got 'Unbreakable' in DivX format, and want to convert to SVCD using CCE 2.5SP, but the picture appears dark, and I want to know whether I can brighten things up ?
    I know that this can be done in TMPGEnc, but is it possible in CCE ?
    Panther
    All say Grrrrrrrrrr......................
  2. Member Gargoyle's Avatar
    Jul 2001
    Southern New Jersey, USA
    I would suggest using VirtualDub to frameserve it to CCE; that way you can use the filters in VDub to adjust the picture ( Video > Filters > Add > "Levels") and get a preview of the output.
    Also, you can use the resize filter in VDub if needed, since CCE can't resize...
  3. Cheers
    I've got the guide for converting DivX to SVCD using CCE, but I didn't know that you used the filters in VirtualDub
    I'll giveit a go
    Panther
