Hi Guys
can you help me I'm trying to create a vcd version of swordfish (R2)Widescreen but when I play the vcd on my dvd player the film is alright in some areas but then goes blocky for a small amount of time then goes back to being a perfect picture.
This is what I'm using
Smart rip
DVD2AVI
Tmpgencoder
Vcdeasy
my settings when encoding are
1. Pal
2. Non Interlace, Field A and 16:9 625 Pal
3. Full screen
any ideas
Paul
What speed did you burn the VCD at? I've had this happen if I burn at a speed higher than 4x.
H -
Hi
It was set to x10 I will try it on x4 i never even looked at the speed setting thanks.
Paul
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
