All movies I seem to download as BIN/CUE files seem to be in NSTC format, I have a PAL TV, how will this effect the quality?
I am burning as VCD with Nero and DVD with Unlead Movie Factory
I will never learn
You don't have to use the bin file, extract the .dat file and convert to PAL with TMPGEnc
WinISO, or ISO Buster, CD Marge etc do the job -
Thanks,
Do I convert the BIN\CUE file to MPG (is that extracting the .dat file) then convert to PAL using TMPGEnc?
and just as a matter of interest what sort of picture would you expect to see from NSTC format on a PAL TV?I will never learn -
Hi,
There is some tricky stuff needed to convert NTSC to PAL. If you don't do it correctly you wil end up with a jerky file (every second will have a repeted frame).
Most PAL TV's made in the last 5 years 'should' play NTSC fine. Worst case you will end up with a black and white picture. -
Yes when you load the Bin file into one of those programs, you will see the contents just like you were viewing it on a VCD. You can open up the folders and see what's inside. Select the .dat file and extract.Originally Posted by lbrothe
Now that you have the data file, just load it into TMPGEnc in the normal way, and select a PAL VCD template. I convert all NTSC to PAL, even though my TV/DVD play NTSC, other peoples might not, and if they borrow one, they wont like black and white movies
The conversion is just fine, apart from pan's down the screen where they can be a bit jerky, other than that the rest is just fine.
You need to find out these things for yourself, I have a 100Hz Widescreen so what happens here may be different on your equipment.
29.97fps To 25fps is just fine...
60Hz V 50Hz
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Video-CD NTSC Film (MPEG-1 352x240 23.976fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
See also
http://forum.vcdhelp.com/userguides/78178.php
NSTC DVD conversion for 29.97fps x264
By txporter in forum Video ConversionReplies: 30Last Post: 18th Feb 2010, 11:50 -
NSTC to PAL, on Mindv Tape
By poacher in forum Video ConversionReplies: 6Last Post: 29th Dec 2009, 15:56 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 14:47 -
Nstc to Pal
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 9th Jul 2008, 15:42 -
Best 1080P Upconverting PAL/NSTC Region Free Player?
By miamiloco in forum DVD & Blu-ray PlayersReplies: 17Last Post: 29th Nov 2007, 09:37
