hope someone can help me with this...
im traying to put a 2nd audio track to a mpeg2 file, so i multiplex the 2 audio tracks with tmpeg, but sometimes i get a mesage saying that the file may cause problems during playback and when i play it, it dont change to the other audio track, or i get a video file that dont have sound, just a bunch of 'clicks'
i tried multiplexing the file with the second audio track, also, demultiplexing it, and then multiplexing the .m2v file with the 2 audio tracks (selecting th type as mpeg2 svcd (vbr)), but nothing...just the same bad results?![]()
what am i doing wrong?, the audio tracks must be mp3, wav, or something else?
please, any help would be apreciated
(sorry for my english)
USE BBmpeg and to mutiplex the 2 audio (mp2) tracks with the video (mpv or m2v) and do not change nothing on it the only thing you can chahge is the size and to cut .
thanks for your help!, but how i get the audio in .mp2 format?, i use dvd2avi to extract the audio and the .d2v file, and then the other audio track..but it extracts it in .wav. or there is a tool that let me convert wav, mp3, etc to .mp2? because when i try to add a mp3 or a wav file bbmpg gives me an error
Hi,
The Simplest way would be TMPGenc. Do an audio only encode and select the bitrate you want.
Better would be to use Toolame. It can be used with the toolame gui, as command prompt or as external encoder in TMPGenc.
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
please help me again, i try to do what you suggest, do an audio only encode, encode the .wav file with toolame, but every time that i want to open in bbmpeg, it gives me this error:
"could not get time pre frame from IDirectDrawStream"
what am i doing wrong? -
Hi,
Are encoding using TMPGenc and TooLame, TooLame + Gui or the command version itself of TooLame ???
Try using only TMPGenc (without Toolame as external encoder.) see what happens than.
Greetz,
Adding 2nd audio track to specific location...
By tweeker404 in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2011, 00:53 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 13:16 -
Adding a 2nd audio track to established videos
By madison13 in forum Newbie / General discussionsReplies: 4Last Post: 9th Feb 2009, 00:39 -
Extracting 2nd audio track from avis
By guy with a stick in forum AudioReplies: 1Last Post: 18th May 2007, 22:54
