Hi,
I donīt succeed to create a two-language SVCD with DVD2SVCD. Choosing German as first, English as second language in the menu the btach runs all through, but when I burn the CD & put it to the standalone DVD it recognizes only the first language. The second remains quiet...
What am I doing wrong? Is it TMPGEnc (I didnīt try CCE yet)? Or a later step like bbMpeg or VCDXBuild?
Did anyone yet succeed to create a 2-lang. SVCD? And which configuration did you use there??
Thanks for your help & best regards,
Michael
Did you rip with DVD2SVCD or with another ripper. I did have problem with dvd2svcd because I ripped with another one and the .ifo file was ok. I did have 2 audio on it. To fix the probleme you must ripp with dvd2svcd. If it is not the probleme, do like me, without dvd2svcd, manually
I did the whole process in DVD2SVCD. (Ripping as well).
As I am not yet that familiar with the cryptic command-line tools I thought DVD2SVCD will help giving me first good results.
Itīs not that the quality in Audio 1 is bad, itīs excellent, but the second Audio track is completely missing (and acc. to the LOG is was multiplexed with bbMPEG)...
Capturing from one PC to a 2nd one
By Smoerble in forum Capturing and VCRReplies: 1Last Post: 18th Jan 2012, 11:22 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 18:34 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 17:46 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 17:29 -
2nd Angle plus subs?
By Jeikobu in forum MacReplies: 2Last Post: 18th Jul 2008, 09:25
