I was trying to convert the audio of my avi to wav like i have done many times before with virtualdub but this time like usual i went into audi and changed to full processing mode but when i hit save wav it said "The requested audio compression is not compatible with th e input format. Check that the sampling rate and channel count of the input match those of the requested format." what do i do?
Results 1 to 11 of 11
Audio > full processing mode
Audio > conversion > 44.1khz
SAVE WAV
Else use
Vdub AC3
http://www.digital-digest.com/dvd/downloads/virtualdub.html
You can also save it and convert later
Audio > direct stream copy
SAVE WAV -
What does it say in the file -> file information in vdub under audio properties?
I have the same problem.
When i look the file information in Vdub it shows unknown codec but 5 channel audio.
I can watch the movie without problems.
Only with the audio i´ve got problems when encoding with vdub and tmpg. -
Unknown codec = Install the Nimo codec pack, and/or DivX 5.02
http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/
wwww.getfromkazaa -
in properties my files says
samling rate 48000hz
channels 5 (stereo)
Sample Precision 0-bit
compression unknown (tag 2000)
preload skew: 28000 samples (.58s)
# of frames 86290
Min/avg/max/total fram size: 28/2335/28000 (196843k) -
Yep that's AC3
If your having problems with Vdub, download "Vdub AC3"
Or save and convert later
SAVE WAV
Make sure you install Nimo, it has the AC3 codec -
When I try to save to wav in Vdub in Full Processing Mode the programm is not able to do it.
I´ve got the Nimo Codec Pack since the first release and update it every new version.
So this is the first movie i´ve got problems with.
When I save to wav with direct stream copy the wav play´s with to high speed. I think 4X.
So I will try Vdub AC3 ( my last hope )
Maybe it works -
OK, you can also use "headac3he" to convert the AC3
http://darkav.de.vu
Reanme your WAV to .AC3 to use the above program, if Vdub AC3 don't work...
AVI to MPG Conversion Audio Problem - please help!
By Nuzy in forum Video ConversionReplies: 4Last Post: 17th Nov 2010, 22:34 -
AVI Conversion - Audio out of sync
By pinovecs in forum Video ConversionReplies: 3Last Post: 17th Oct 2008, 16:11 -
Audio Offset In Avi Conversion
By Scav2003 in forum MacReplies: 4Last Post: 4th Feb 2008, 13:26 -
audio conversion in avi file
By Ogilvy in forum Newbie / General discussionsReplies: 4Last Post: 30th Aug 2007, 19:35 -
No audio when doing AVI -> DVD conversion
By molamola in forum Video ConversionReplies: 5Last Post: 27th May 2007, 09:04
