I think we have move far away from the topicOriginally Posted by HyperianIf you can make the ghost image you can then put it on a CD, or use WinAR with no compression to split it across several disks?.
Results 31 to 38 of 38
No no no, I'm not going to do the ghosting and reformating, it's too much work, besides I finally finished uploading the asf file to my friend, he said the file has 34 errors and header and end part is screwed up. He was able to convert it, but the sound is horrible and it has a 4 seconds delay. I guess I'll have to wait till a better version comes out.
It's uh a Kylie video, Kylie Mingoue, the singer. It's her live concert that is in asf format. Trying to convert it cause asf is so crappy
Na.. all the Kylie video's are crap not just ASF
Didn't you know that ?
I downloaded about 20 of those on Kazaa for someone the other day, is it not on there ?
I just did a quick search 60 + found mostly AVI some Mpeg -
Kylie is not crap!!!
Yea there're like tons of Kylie vids but the one i want to convert is only in asf format -
Take a look at my post on the WMV conversion, GraphEdit works very well
http://www.vcdhelp.com/forum/viewtopic.php?t=111182&highlight= -
Ah thanks, I will, It looks like I'll be doing reformatting soon, installing winxp w/sp1.... I will have to somehow find time which I don't have...
Reencoding issue
By woecarlson in forum Blu-ray RippingReplies: 8Last Post: 12th Apr 2011, 19:19 -
Audio-only reencoding?
By woecarlson in forum Blu-ray RippingReplies: 0Last Post: 11th Apr 2011, 15:30 -
No Reencoding
By themaster1 in forum Authoring (DVD)Replies: 6Last Post: 27th Oct 2010, 11:28 -
AsfTools
By devilcoelhodog in forum Video ConversionReplies: 0Last Post: 30th Jan 2010, 11:53 -
Reencoding quality
By dexter30 in forum Newbie / General discussionsReplies: 5Last Post: 6th Nov 2008, 17:07
