Ok, I am ditching the re-encoding, see my post as below for details of what was going wrong...http://www.vcdhelp.com/phpBB/viewtopic.php?topic=54391&forum=3&2
I have now decided to demux the audio, re-encode the video to smooth it out a bit, the re-mux it all back together with the new and improved picture.
But, it is slightly out of sync.
I have tried Virtual Dub but since it creates AVIs I have not enough room to shift the audio around.
Are there any other tools which will shift the audio slightly so it is back in sync.
I appreciate tons any help!
If you can help on this, I am BEGGIN your advice as this is getting my down big time!
Ta!
Gray
Demux the video and use BBMPeg to remux it with shifted audio (see the Edit tab at the left).
Delaycut question about 6 chan ac3 out of sync when 2 chan is in sync
By B2K24 in forum AudioReplies: 3Last Post: 27th Apr 2009, 17:10 -
newbie question: need freeware DVD authoring tool
By kbflower in forum Authoring (DVD)Replies: 7Last Post: 20th Jul 2008, 21:45 -
tool to sync audio and video
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2008, 21:11 -
Hauppage Tweek Tool question
By AlecWest in forum Capturing and VCRReplies: 2Last Post: 6th Jul 2007, 19:25 -
burning tool question.
By cowboysroy31 in forum Newbie / General discussionsReplies: 1Last Post: 5th Jun 2007, 00:08
