Hello
I'm new at this and I was wondering if you guys could maybe help me out a bit. Any help will be greatly appreciated. So far I have had no probs converting files, but it takes a long time and I wanted to know if thats just the way it is of if I can do something about it. When I convert an AVI to MPG it takes about 40 mins to do 30 mins worth of video. Is this right? Can it be made faster? Also how can I tell if the file will fit on a 80 min CD? So far I figured that SVCD is about 38 to 40 mins of video on a 80 min CD. Is that right?
Here are my PC specs
P4 2.4ghz
512 RD ram
2 x 40GB maxtor 7200rpm drives with 10gb free total
GeForce2 GTS 64mb Video
SB Live sound
TDK Velocd 16x10x40
Thanks guys
First....I wouldn't complain about 40 per 30 minutes of video....thats almost real time...It takes my dinasor( see spec) about 12-14 hours for an hour and a half movie.....Once I did a Kwang templat encode that took 39 hours for a 87 minute long flick...(shakes the clown...the ben hur of alcoholic clown movies)
Where was I...Oh for standard VCD roughly 80 minutes of video on a 80 min CDR.......SVCD 40 minutes is about average....Nonstandard VCD I've goten 2hours 16 minutes on...good quality. -
Originally Posted by Matrixaddict
You put me off getting one now
Do you have the latest version of TMPGEnc, are you changing any of the settings ?
Ah, I can see you have Windows 2000, dont know about that, I use Win98SE -
Thanks guys
Another issue I got going is that sometimes I need to use 4 cds for a 2hr movie. Can I fit more time in one cd while keeping the quality high. I use TMPGEnc but I dont change any settings because I dont know how to.
Any help would be appreciated. -
If they are 320 Minuet long movies then yes it would take 4 VCD's, unless your using SVCD ?
What is the length of the movies, they mostly fit on 2 VCD's
Converting Avi to Mpg using ffmpeg
By sumit_pankaj in forum Video ConversionReplies: 5Last Post: 31st May 2020, 20:42 -
converting flv to avi/mpg
By nimrodm in forum Video ConversionReplies: 1Last Post: 14th Feb 2010, 07:05 -
Converting MPG to AVI type2 (batch)
By statman24 in forum Video ConversionReplies: 8Last Post: 19th Jul 2007, 04:30 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 10:07 -
Problem converting from .AVI or .MPG -> DVD
By ConaHead in forum Video ConversionReplies: 9Last Post: 15th May 2007, 22:13
