ok.. i converted 700+ pics in to VCD 2.0 mpeg files. the total size it less then 60MB.. i used tmpgnec to convert them and all the setting were right.
but when i try to burn it with nero 5582, it says that a VCD can only have a max of 98 files!!
is there a program that would allow me to burn more then 98 files? i really dont want to waste 7 cdrs...
Yes....see "how to's" on the left....Two below support up to 1900 images.. http://www.vcdhelp.com/dvdpictureshow.htm
http://forum.vcdhelp.com/userguides/92056.php
But for me...And you converted to mpg's right?? I would take groups of say ten to twenty pics and join their clips together using TMPG cut/join tool...Then you only have 50-70 files for nero. -
crap, how did i miss the guides? i didnt know they had guide for picture vcds! DOH!
well i could do that, but my converted pics are like less then one second each so they zoom by fast! but i see what you are sayin.. -
I see that wouldn't really work...
I'd use vcdeasy or dvdpictureshow then...naturaly DVDpicture show has more options (like music)......but VCDeasy is free..
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 01:06 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 04:52 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 07:41
