ok, here we go. my first post. i used the search function for this but didn't get any useful results, so i gotta post this here...
i use the pioneer dv 343 and i was told that there was no way to unlock the region code manually with a hack but accidentally found this page with a hack. everything fine until now...
but the guy who reported the second hack (klick) stressed that he does not know how often you can change the code.
so this is my question: did anybody try this? how often can you switch the region codes? with which hack, #1 or #2? is #1 suggested to work each time i switch the codes without any limitation?
As far as I know, its not possible to make a Pioneer player region free by using the remote to enter a 'hack'.
HOWEVER
If you check out my post titled:
All PIONEER Owners, want REGION FREE - w/no hardware mods?!?
You should be able to play DVDs from any other region.
PLEASE, PLEASE! Vote on the poll connected to my post, even if this doesn't work - no-one yet has even replied but as far as I can see, there are no other multiple-machine pioneer hacks apart from mine! Where's all my thanks?!? Just kidding!SUPPORT : http://www.fightdivx.com
Piracy impacts the lives of innocents victims
such as Record Execs. and CEO's. Don't
hurt these poor sweet babies, ahh.............. -
yes the hack on this site worked -- only 10 times i sem to recall and it doesnt change anymore .. it may have been less than that even.. somewhere between 5 and 10
as for the other method listed at
http://www.vcdhelp.com/forum/viewtopic.php?t=127380&highlight=
i havnt tried it -- have to print it out or something .. looks like you just keep pressing buttons till it plays :o hehehe -
Be sure to try the
I am desperate to know if it works on all pioneers with a search/search mode button
remember - technique must be applied each disc is play but only takes a few seconds so dont whine and bitch about it! + you can skip past the annoying intro parts by accessing the film directly, et voila.SUPPORT : http://www.fightdivx.com
IMPORTANT UPDATE!
THE METHOD POSTED A FEW DAYS AGO CONTAINED AN ERROR - I FORGOT TO MENTION ONE MAJOR POINT WHEN WRITING. IF ANYONE HAS ATTEMPTED TO USE THIS METHOD WITHOUT SUCCESS, PLEASE TRY THE DIRECTIONS ON THE REVISED POST WHICH ARE THE CORRECT ONES.SUPPORT : http://www.fightdivx.com
region code hack
By elpini in forum Newbie / General discussionsReplies: 5Last Post: 3rd Sep 2025, 18:29 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Region hack code
By Shopgirl in forum DVD & Blu-ray PlayersReplies: 3Last Post: 25th Dec 2010, 18:39 -
Need Region Code Hack for PIONEER AVH-P5900DVD
By kratzy in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Dec 2007, 09:14 -
Region free hack/code for pioneer XV-HTD520?
By efirtion in forum DVD & Blu-ray PlayersReplies: 2Last Post: 11th Dec 2007, 11:21
