yea its skipping...i encode them with tmpgenc and i do all the right templates and everything...and i burn at the right mode...with nero...and some of my dvd rips skip..not all but some..like i got half baked and it skips...am i doing something wrong?...only some movies tho not all...can any1 help me out?
Field Order is incorrect, Check your source with DVD2AVI will reveal much
about your rips.
Just my 2 cents,
Necro -
i dont understand...i follow the guide in newbie section...i dunno i will just download that thing and try it out...any more tips?
Sorry for the late response, moving from work to home.
Perhaps the Field Order issue i suggested is premature in regards to what type of (S)VCD you're trying to create.
Can you fill in your coding specs for your (S)VCD.
\Necro -
i making normal VCD's and the movie is half baked DIVX rip i got from kazaa...i do all the steps and since its 30 fps i put it on NTCS etc...i do all those steps...but just now i tried something for part2 of the movie..i went in option of tmpgenc and i put motion search on high quality and i encoded about 10 seconds and it seemed ok...but im still not sure..i will encode it overnight since it takes like 2 hours for this piece of junk to do
Perhaps this old thread might be some use to you...
http://www.vcdhelp.com/forum/viewtopic.php?t=98462&highlight=
I remember when i first posted here i also had the same problem.
Kudos to HillJack, as he was no doubt the one who solve my jerky, pausing, skipping dilemma.
\Necro
Timecode skipping
By rds11 in forum EditingReplies: 1Last Post: 23rd Dec 2010, 10:24 -
Skipping - stuttering
By bryankendall in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2010, 12:55 -
movie skipping
By mujin in forum Newbie / General discussionsReplies: 4Last Post: 1st Feb 2009, 13:37 -
New music skipping
By Jeikobu in forum Portable VideoReplies: 0Last Post: 24th Jan 2009, 14:13 -
HI8 Skipping
By jgeise01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Aug 2007, 02:58
