  1. First let me tell you my system : P4 1,6Ghz, 512 MB, geForce 2MX/MX 400, sound blaster Live!, windows XP pro
    So, I have installed in my PC the following programs : ffdshow, nimo-pack (codecs), VirtualDub and msdv204.exe (a DV codec to see DV avi files in VirtualDub, it works fine)...
    BUT
    but the programm i use for montage is Premier. And now, Premier seems to work more slowly... the monitor window freezes, and sometime the program crashes especially when I turn on my Camcorder !!!. It says (when ending) that MMSwitch.ax file has an error or something like this. Why is happenig this ? I was happy to make virtualdub to play DV avi files and now I'm in trouble again !!! any idea ???? plz help
  2. Free Flying Soul liquid217's Avatar
    Feb 2002
    uninstall the nimo codec pack...there are some directshow filters that interfere with some of the other directshow plugins.
    also msdv204.exe is mainconcepts DV codec (i think i gave you the link to it doday). It is not freeware, and will have a logo on it until it is purchased from mainconcept (pretty good investment, imho)
  3. How to uninstall this nemo pack ? I made the basic installation and there is no nemo pack in my programs or somewhere else. Should I install again whole the programm and then uninstall it ? (if it is intalled with all componets it creates a icon in start->programs menou of window with uninstall feature).
    You think this is my problem ? nimo pack ? ... by the chance, the DV codec you told me works fine in VirtualDub, I have also find another DV codec from Canopus (something like this, it was with Main Concept DV codec) should I download it or not ? (I'm somehow a niewbie in all these codecs... I'm working on filmmaking and this digital things is really an abyss in which I have to swim )
    thanks.
  4. Free Flying Soul liquid217's Avatar
    Feb 2002
    yes, that is what i would do. The nimo codec pack is a very nice concept but sometimes it can interfere with other components in directshow
  5. Also I want to ask you something.
    The Main Concept DV codec gave me the chance to see dv avi files in VirtualDub. But I still canot capture. I have a DV Camcorder and I'm using firewire card. VirtualDub doesn't send me an error but it also doesn't capture. any solution ?
    Also, when I have checked both DV-playack and Windows playback options in Premier , I can see perfect the video in my camcorder's LCD but in monitor window it is very "conclusive" (don't know the english terminology). Any idea ?
  6. Free Flying Soul liquid217's Avatar
    Feb 2002
    virtualdub can not capture dv through firewire , please refer to this
    http://www.vcdhelp.com/capture.htm#fire
